While we try to keep this article up to date, it’s often hard due to the many updates to our firmware. If any updates/edits need to be made to this article, please comment on this thread: Wiki - General Feedback/Suggestions Thread
Please select the make/model from the side bar to go to your specific switch to see what bulbs are compatible. Below are common examples of the various bulbs:
Figure 1.1 - Common Bulb Types
Dimmer Switches
Black Series (SKU: LZW31)
Please start with the type of bulb (ie: A19, BR30, etc - Shown in Figure 1.1) and click on the triangle to expand each list.
NOTE: These dimmers use MOSFET, Leading-Edge technology, which are different than the Fan/Light switch which uses TRIAC, Leading-Edge technology – so the bulb compatibility will be different.
Compatible
Can
Compatible |
Picture |
Brand |
Style |
Base |
Wattage (Equivalent) |
Kelvin |
Model |
Min Setting |
Max Setting |
Where to Buy |
Notes |
Yes |
Cree |
BR30 |
E26 |
65W |
2700K |
TBR30-06527FLFH25-12DE26-1-12 |
15 |
100 |
Amazon, Amazon.ca, Home Depot
Yes |
Feit |
BR30 |
E26 |
65W |
2700K |
Varies |
0 |
100 |
Amazon |
It appears the SKU listed here: CEBR30/927/6 has been changed to the one listed on Amazon. |
No |
GE |
BR30 |
E26 |
65W |
2700K |
LED10DR303/827W |
N/A |
N/A |
Amazon, Amazon.ca
Not Compatible - Produces buzzing. |
Yes |
Philips |
R20 |
E26 |
75W |
2700K |
545020 |
20 |
99 |
Confirmed here
___________ |
___________ |
_________ |
______ |
_____ |
_____________ |
____________ |
_______________________________ |
_____ |
_____ |
____________________________________ |
Candelabra
Compatible |
Brand |
Style |
Base |
Kelvin |
Model |
Min Setting |
Max Setting |
Where to Buy |
Notes |
Yes |
Cree |
Candelabra |
E12 |
75W |
2700K (Warm), 5000K (Cold) |
TB11-07027MDCH25-12DE12-1-12, TB11-07050MDCH25-12DE12-1-12 |
30 |
100 |
Amazon - 2700K, Amazon - 5000K, Amazon.ca - 2700K, Amazon.ca - 5000K
Confirmed here: Compatible Bulbs for Dimmer Switch (Gen 2) - #90 by skarden
Yes |
GE |
Candelabra |
E12 |
Various |
Various |
Compatible w/all Relax Line |
15 |
100 |
Amazon, Amazon.ca, Home Depot, Lowes
Confirmed here: Compatible Bulbs for Dimmer Switch (Gen 2) - #63 by jbilodea (using E26 adapter) |
Yes |
GE |
Candelabra |
E12 |
60W |
2700K (Warm) |
42550 (Lowes), 35550 (Walmart) |
Unsure |
100 |
Amazon, Amazon.ca, Lowes, Walmart
No |
ILAMIQI |
Candelabra |
E12 |
10W |
3000K (Warm) |
Applies to all variations on Amazon |
N/A |
N/A |
Amazon, Amazon.ca
Not Compatible |
No |
Philips |
Candelabra |
E12 |
60W |
5000K (Cold) |
550300 |
N/A |
N/A |
Home Depot |
Not Compatible |
___________ |
_________ |
______________ |
_________ |
____________ |
______________ |
________________________________________ |
_____ |
_____ |
___________________________________________________ |
Flood/Spot
Compatible |
Brand |
Style |
Wattage |
Kelvin |
Model |
Min Setting |
Max Setting |
Where to Buy |
Notes |
Yes* |
Commercial Electric |
Flood Light |
28W |
3000K (Warm) |
SPTM2-2802 |
0 |
100 |
Home Depot |
* Need to set parameters 1-4 to 0 as this is not a dimmable bulb. Use at your own risk. |
___________ |
_________ |
______ |
___________ |
____________ |
_____ |
_____ |
Recessed/Panel
Brand |
Compatible |
Verified Users |
Picture |
Style |
Base |
Wattage |
Kelvin |
Model |
Min Setting |
Max Setting |
Where to Buy |
Notes |
Yes |
2 |
Recessed |
6 in. |
11W |
2700K - 5000K |
Model#: 53804101, SKU#: 1003456565 |
44 |
99 |
Home Depot |
Ramp Rate must be set to 0 to properly control the Halo Night Light via on/off/on per this thread
No |
Flat Panel |
1-4 ft. |
80W (Eq) |
4000K (Cool) |
74031/HD-G2 |
N/A |
N/A |
Home Depot |
Not Compatible |
Yes |
Eaton |
Recessed |
4 in. |
65W (Eq) |
3000K (Warm) |
RA5606930WHR |
15 |
100 |
Yes |
Eaton |
Recessed |
4 in. |
65W (Eq) |
4000K (Cool) |
SMD4S6940WH |
15 |
100 |
Yes |
Eaton |
Recessed |
6 in. |
65W (Eq) |
3000K (Warm) |
ML5609930 |
Unsure |
100 |
Yes |
Eaton |
Recessed |
6 in. |
65W (Eq) |
3000K (Warm) |
LT460WH6930R |
Unsure |
100 |
Yes |
Eaton |
Recessed |
6 in. |
65W (Eq) |
4000K (Cool) |
RL560WH6940R |
Unsure |
100 |
Yes |
Eaton |
Recessed |
6 in. |
65W (Eq) |
2700K - 5000K |
SMD6R6940WH |
Unsure |
100 |
No |
FENG@YE |
Recessed |
4 in. |
65W (Eq) |
3000K (Warm) |
AFR4C-0930 |
N/A |
N/A |
Amazon, Amazon.ca
Not Compatible |
Yes |
Hamilton Hills |
Recessed |
8 in. |
15W |
Varies |
HH1061-L, HH1048, HH1085-L |
Unsure |
100 |
Amazon, Amazon.ca
Amazon link will take you to the bronze variation, but you can choose whichever. |
No |
Hyperikon |
Recessed |
14 in |
15W |
3000K (Warm) |
4422510131 |
N/A |
N/A |
Amazon, Amazon.ca
Not Compatible |
No |
Lithonia |
Recessed |
Varies |
Varies |
Varies |
Applies to all Lithonia fixtures on the Amazon listing |
N/A |
N/A |
Amazon |
Not Compatible |
Yes* |
Quoizel |
Flush Mount |
12 in. |
17W |
2700K (Warm) |
PCBZ1612C |
40 |
60 |
Lowes |
* Not recommended due to the cost and low range of dimming |
No |
Sea Gull |
Recessed |
6 in. |
14W |
3000K (Warm) |
14701S-15 (Discontinued) |
N/A |
N/A |
Sea Gull Store |
Not Compatible |
No |
Sunco |
Recessed |
4 in. |
60W (Eq) |
2700K (Warm) |
SC4SLIM12PK27K |
N/A |
N/A |
Amazon |
Not Compatible |
No |
Trans Globe Lighting |
Recessed |
6 in. |
13W |
2700K (Warm) |
LED-30015 ROB |
N/A |
N/A |
Trans Globe Lighting Store |
Not Compatible |
Yes |
WAC Lighting |
Recessed |
15 in. |
Varies |
Varies |
Applies to all WAC fixtures on the Amazon listing |
Unsure |
100 |
Amazon, Amazon.ca, WAC Lighting
___________ |
___________ |
_____________ |
______________ |
_________ |
____________ |
______________ |
_______________________________________________________ |
_________ |
_________ |
Standard
Compatible |
Brand |
Style |
Base |
Kelvin |
Model |
Min Setting |
Max Setting |
Where to Buy |
Notes |
Yes |
Cree |
A19 |
E26 |
80W |
2700K (Warm) |
SA19-04627MDFD-12DE26-1-14 |
15 |
100 |
Amazon, Amazon.ca
Yes |
Cree |
A19 |
E26 |
60W |
3000K (Warm) |
TA19-08027MDFH25-12DE26-1-12 |
15 |
100 |
Yes |
EcoSmart |
A19 |
E26 |
60W |
3000K (Warm) |
A810SS-Q1D-01 |
Not Sure |
100 |
No |
Feit |
A19 |
E26 |
60W |
3000K (Warm) |
BPOM60/830/LED |
N/A |
N/A |
No |
Feit |
A19 |
E26 |
40W |
2700K (Warm) |
OM40DM/927CA/LED |
N/A |
N/A |
Yes |
GE |
A19 |
E26 |
60W |
2700K (Warm) |
89623 |
Not Sure |
100 |
Amazon, Amazon.ca
CFL Bulb |
Yes |
GE |
A19 |
E26 |
Varies |
Varies |
Compatible w/all Reveal Line |
42 |
84 |
Compatible per this thread
Yes |
GE |
A19 |
E26 |
Varies |
Varies |
42 |
84 |
No |
IKEA |
A19 |
E26 |
Not Sure |
2700K (Warm) |
RYET Line |
N/A |
N/A |
IKEA |
___________ |
_________ |
______ |
_____ |
_____________ |
____________ |
_____ |
_____ |
Track
Compatible |
Brand |
Style |
Base |
Kelvin |
Model |
Min Setting |
Max Setting |
Where to Buy |
Notes |
Yes |
Feit |
MR16 |
GU5.3 |
50W |
3600K |
EXN |
Unsure |
Unsure |
Amazon |
___________ |
_________ |
______________ |
_________ |
____________ |
______________ |
_________ |
_____ |
_____ |
_______________ |
______ |
Non-Compatible
Can
Brand |
Picture |
Style |
Base |
Kelvin |
Type |
Model |
Min Setting |
Max Setting |
Where to Buy |
Verified Users |
Notes |
GE |
BR30 |
E26 |
65W |
2700K |
Dimmable |
LED10DR303/827W |
N/A |
N/A |
Amazon, Amazon.ca
1 |
___________ |
___________ |
_____________ |
______ |
________ |
________________ |
____________ |
___________ |
_____ |
_____ |
________ |
Candelabra
Brand |
Picture |
Style |
Base |
Kelvin |
Type |
Model |
Min Setting |
Max Setting |
Where to Buy |
Verified Users |
Notes |
Philips |
Candelabra |
E12 |
60W |
5000K (Cold) |
Dimmable |
550300 |
N/A |
N/A |
Home Depot |
1 |
Not Compatible |
___________ |
___________ |
_____________ |
______ |
________ |
________________ |
____________ |
___________ |
_____ |
_____ |
________ |
Flood/Spot
None Listed – If you have a Flood/Spot bulb that isn’t compatible, please list it here so we can add it (or email us if you’d prefer not to post).
Recessed/Panel
Brand |
Compatible |
Verified Users |
Picture |
Style |
Base |
Wattage |
Kelvin |
Model |
Min Setting |
Max Setting |
Where to Buy |
Notes |
No |
Flat Panel |
1-4 ft. |
80W (Eq) |
4000K (Cool) |
74031/HD-G2 |
N/A |
N/A |
Home Depot |
Not Compatible |
No |
FENG@YE |
Recessed |
4 in. |
65W (Eq) |
3000K (Warm) |
AFR4C-0930 |
N/A |
N/A |
Amazon, Amazon.ca
Not Compatible |
No |
Hyperikon |
Recessed |
14 in |
15W |
3000K (Warm) |
4422510131 |
N/A |
N/A |
Amazon, Amazon.ca
Not Compatible |
No |
Lithonia |
Recessed |
Varies |
Varies |
Varies |
N/A |
N/A |
Amazon |
Not Compatible |
No |
Sea Gull |
Recessed |
6 in. |
14W |
3000K (Warm) |
N/A |
N/A |
Sea Gull Store |
Not Compatible |
No |
Sunco |
Recessed |
4 in. |
60W (Eq) |
2700K (Warm) |
SC4SLIM12PK27K |
N/A |
N/A |
Amazon |
Not Compatible |
No |
Recessed |
6 in. |
13W |
2700K (Warm) |
LED-30015 ROB |
N/A |
N/A |
Not Compatible |
___________ |
___________ |
_____________ |
______________ |
_________ |
____________ |
______________ |
_________ |
_________ |
Standard
Compatible |
Brand |
Style |
Base |
Kelvin |
Model |
Min Setting |
Max Setting |
Where to Buy |
Notes |
Yes |
Cree |
A19 |
E26 |
80W |
2700K (Warm) |
15 |
100 |
Amazon, Amazon.ca
Yes |
Cree |
A19 |
E26 |
60W |
3000K (Warm) |
15 |
100 |
Yes |
EcoSmart |
A19 |
E26 |
60W |
3000K (Warm) |
A810SS-Q1D-01 |
Not Sure |
100 |
No |
Feit |
A19 |
E26 |
60W |
3000K (Warm) |
BPOM60/830/LED |
N/A |
N/A |
No |
Feit |
A19 |
E26 |
40W |
2700K (Warm) |
OM40DM/927CA/LED |
N/A |
N/A |
Yes |
GE |
A19 |
E26 |
60W |
2700K (Warm) |
89623 |
Not Sure |
100 |
Amazon, Amazon.ca
CFL Bulb |
Yes |
GE |
A19 |
E26 |
Varies |
Varies |
42 |
84 |
Yes |
GE |
A19 |
E26 |
Varies |
Varies |
42 |
84 |
No |
IKEA |
A19 |
E26 |
Not Sure |
2700K (Warm) |
RYET Line |
N/A |
N/A |
IKEA |
___________ |
_________ |
______ |
_____ |
_____________ |
____________ |
_____ |
_____ |
Track
Compatible |
Brand |
Style |
Base |
Kelvin |
Model |
Min Setting |
Max Setting |
Where to Buy |
Notes |
Yes |
Feit |
MR16 |
GU5.3 |
50W |
3600K |
EXN |
Unsure |
Unsure |
Amazon |
___________ |
_________ |
______________ |
_________ |
____________ |
______________ |
_________ |
_____ |
_____ |
_______________ |
______ |
Red Series (SKU: LZW31-SN)
Can
Compatible |
Brand |
Style |
Base |
Kelvin |
Model |
Min Setting |
Max Setting |
Where to Buy |
Notes |
Yes |
Cree |
BR30 |
E26 |
65W |
2700K |
15 |
100 |
Yes |
Feit |
BR30 |
E26 |
65W |
2700K |
Varies |
0 |
100 |
Amazon |
No |
GE |
BR30 |
E26 |
65W |
2700K |
LED10DR303/827W |
N/A |
N/A |
Amazon, Amazon.ca
Yes |
Philips |
R20 |
E26 |
75W |
2700K |
545020 |
20 |
99 |
Confirmed here
___________ |
_________ |
______ |
_____ |
_____________ |
____________ |
_____ |
_____ |
Candelabra
Compatible |
Brand |
Style |
Base |
Kelvin |
Model |
Min Setting |
Max Setting |
Where to Buy |
Notes |
Yes |
Cree |
Candelabra |
E12 |
75W |
30 |
100 |
Yes |
GE |
Candelabra |
E12 |
Various |
Various |
15 |
100 |
Yes |
GE |
Candelabra |
E12 |
60W |
2700K (Warm) |
Unsure |
100 |
No |
ILAMIQI |
Candelabra |
E12 |
10W |
3000K (Warm) |
N/A |
N/A |
Amazon, Amazon.ca
Not Compatible |
No |
Philips |
Candelabra |
E12 |
60W |
5000K (Cold) |
550300 |
N/A |
N/A |
Home Depot |
Not Compatible |
___________ |
_________ |
______________ |
_________ |
____________ |
______________ |
_____ |
_____ |
Flood/Spot
Compatible |
Brand |
Style |
Wattage |
Kelvin |
Model |
Min Setting |
Max Setting |
Where to Buy |
Notes |
Yes* |
Flood Light |
28W |
3000K (Warm) |
SPTM2-2802 |
0 |
100 |
Home Depot |
___________ |
_________ |
______ |
___________ |
____________ |
_____ |
_____ |
Recessed/Panel
Compatible |
Brand |
Style |
Base |
Wattage |
Kelvin |
Model |
Min Setting |
Max Setting |
Where to Buy |
Notes |
Yes* |
Recessed |
6 in. |
11W |
2700K - 5000K |
53804101 |
0 |
100 |
Home Depot |
* Need to set Parameters 1-4 to 0 as this is not a dimmable bulb. Use at own risk. |
No |
Flat Panel |
1-4 ft. |
80W (Eq) |
4000K (Cool) |
74031/HD-G2 |
N/A |
N/A |
Home Depot |
Not Compatible |
Yes |
Eaton |
Recessed |
4 in. |
65W (Eq) |
3000K (Warm) |
RA5606930WHR |
15 |
100 |
Yes |
Eaton |
Recessed |
4 in. |
65W (Eq) |
4000K (Cool) |
SMD4S6940WH |
15 |
100 |
Yes |
Eaton |
Recessed |
6 in. |
65W (Eq) |
3000K (Warm) |
ML5609930 |
Unsure |
100 |
Yes |
Eaton |
Recessed |
6 in. |
65W (Eq) |
3000K (Warm) |
LT460WH6930R |
Unsure |
100 |
Yes |
Eaton |
Recessed |
6 in. |
65W (Eq) |
4000K (Cool) |
RL560WH6940R |
Unsure |
100 |
Yes |
Eaton |
Recessed |
6 in. |
65W (Eq) |
2700K - 5000K |
SMD6R6940WH |
Unsure |
100 |
No |
FENG@YE |
Recessed |
4 in. |
65W (Eq) |
3000K (Warm) |
AFR4C-0930 |
N/A |
N/A |
Amazon, Amazon.ca
Not Compatible |
Yes |
Hamilton Hills |
Recessed |
8 in. |
15W |
Varies |
Unsure |
100 |
Amazon, Amazon.ca
No |
Hyperikon |
Recessed |
14 in |
15W |
3000K (Warm) |
4422510131 |
N/A |
N/A |
Amazon, Amazon.ca
Not Compatible |
No |
Lithonia |
Recessed |
Varies |
Varies |
Varies |
N/A |
N/A |
Amazon |
Not Compatible |
Yes* |
Quoizel |
Flush Mount |
12 in. |
17W |
2700K (Warm) |
PCBZ1612C |
40 |
60 |
Lowes |
No |
Sea Gull |
Recessed |
6 in. |
14W |
3000K (Warm) |
N/A |
N/A |
Sea Gull Store |
Not Compatible |
No |
Sunco |
Recessed |
4 in. |
60W (Eq) |
2700K (Warm) |
SC4SLIM12PK27K |
N/A |
N/A |
Amazon |
Not Compatible |
No |
Recessed |
6 in. |
13W |
2700K (Warm) |
LED-30015 ROB |
N/A |
N/A |
Not Compatible |
Yes |
WAC Lighting |
Recessed |
15 in. |
Varies |
Varies |
Unsure |
100 |
___________ |
______________ |
_________ |
____________ |
______________ |
_________ |
_________ |
Standard
Compatible |
Brand |
Style |
Base |
Kelvin |
Model |
Min Setting |
Max Setting |
Where to Buy |
Notes |
Yes |
Cree |
A19 |
E26 |
80W |
2700K (Warm) |
15 |
100 |
Amazon, Amazon.ca
Yes |
Cree |
A19 |
E26 |
60W |
3000K (Warm) |
15 |
100 |
Yes |
EcoSmart |
A19 |
E26 |
60W |
3000K (Warm) |
A810SS-Q1D-01 |
Not Sure |
100 |
No |
Feit |
A19 |
E26 |
60W |
3000K (Warm) |
BPOM60/830/LED |
N/A |
N/A |
No |
Feit |
A19 |
E26 |
40W |
2700K (Warm) |
OM40DM/927CA/LED |
N/A |
N/A |
Yes |
GE |
A19 |
E26 |
60W |
2700K (Warm) |
89623 |
Not Sure |
100 |
Amazon, Amazon.ca
CFL Bulb |
Yes |
GE |
A19 |
E26 |
Varies |
Varies |
42 |
84 |
Yes |
GE |
A19 |
E26 |
Varies |
Varies |
42 |
84 |
No |
IKEA |
A19 |
E26 |
Not Sure |
2700K (Warm) |
RYET Line |
N/A |
N/A |
IKEA |
___________ |
_________ |
______ |
_____ |
_____________ |
____________ |
_____ |
_____ |
Track
Compatible |
Brand |
Style |
Base |
Kelvin |
Model |
Min Setting |
Max Setting |
Where to Buy |
Notes |
Yes |
Feit |
MR16 |
GU5.3 |
50W |
3600K |
EXN |
Unsure |
Unsure |
Amazon |
___________ |
_________ |
______________ |
_________ |
____________ |
______________ |
_________ |
_____ |
_____ |
_______________ |
______ |
Fan/Light Switch
Red Series (SKU: LZW36)
For bulbs: Please start with the type of bulb (ie: A19, Candelabra, etc - Shown in Figure 1.1) and click on the triangle to expand each list.
For fans: Please click on the triangle next to fans to expand the list.
NOTE: The fan/light switch uses TRIAC, Leading-Edge technology, which is different then the Dimmer switches which use MOSFET, Leading-Edge technology – so the bulb compatibility will be different.
Candelabra
Standard
Compatible |
Brand |
Style |
Base |
Kelvin |
Model |
Min Setting |
Max Setting |
Where to Buy |
Notes |
Yes |
Sylvania |
A19 |
E26 |
40W |
Amber Glow |
75347 |
Unsure |
Unsure |
Amazon |
Confirmed here: Compatible Bulbs/Fans for Fan & Light Switch - #2
___________ |
_________ |
______________ |
_________ |
____________ |
______________ |
______________ |
_____ |
_____ |
_________________ |
On/Off Switches
Black Series (SKU: LZW30)
The on/off switches in theory should work with any bulb. However, we have seen some issues with T8 type bulbs.
Red Series (SKU: LZW30-SN)
Test
